michel1972 Geplaatst April 27, 2008 Rapporteren Share Geplaatst April 27, 2008 Te koop aangeboden: 2 NIEUWE ACOS COIL SPACERS TJ-XJ-ZJ FRONT PAIR. Fits: - TJ Wrangler, 1997-06, Front - XJ Cherokee, 1984-01, Front - MJ Comanche, 1986-92, Front - ZJ Grand Cherokee, 1993-98, Front Adjusting ride height on coil sprung Jeeps® is fast, convenient and easy with Adjustable Coil Over Spacers from JKS. Whether adding clearance for larger tires, compensating for heavy accessories, or trimming an unlevel vehicle, these extraordinary spacers provide convenient control of ride height without removing any suspension components! JKS Adjustable Coil Over Spacers feature billet aluminum construction, providing an appearance as impressive as their function. The threaded design accommodates changes to your vehicle with a level of precision impossible with ordinary poly spacers. Heavy duty adjustment rings are easy to operate with the suspension unloaded, using only an allen wrench to lock and unlock. Mounted to the OE spring retainers, the Adjustable Coil Over Spacer functions as the upper spring seat using a new Dura-Thane™ isolator pad to dampen road noise. Installation automatically increases ride height 1.25" for front applications, and 2.125" for rear applications, with a maximum increase of 3.5" and 3.375" respectively. New polyurethane bump stops are supplied, as well as anti-corrosion mounting hardware. Vaste Prijs € 150,- Citeren Link naar opmerking Deel via andere websites More sharing options...
