michel1972 Geplaatst April 27, 2008 Rapporteren Share Geplaatst April 27, 2008 Te koop aangeboden: 2 Nieuwe JKS Rear Bar Pin to Cross Bolt Conversion For 84-06 Jeep Wrangler TJ & Cheorkee XJ JKS Bar Pin Eliminators The Bar Pin EliminatorsTM were designed to eliminate rattles or thumping causes by a weak bar pin. Because of the O.E.M. bar pin design, this symptom will only get worse with time. With the . bar pin there is no compression or preload on the bushing, which will let the bushing move freely within the shock loop eye. Any slight bump will be absorbed by the bushing before the bushing has a chance to transfer its load to the shock itself. They will automatically preload the bushing to the desired dimension specified by bushing manufacturers. Compressing the bushing in this fashion actually distorts the bushing is such a manner as to fill the shock loop eye completely. Now there is no chance for any rattles or thumping noises. For 1997-05 Wrangler Vehicles - Top Rear Shock Mounts. REAR SHOCK ONLY, TOP MOUNT, SOLD IN PAIR 84-01 XJ, 97 & UP TJ Prijs € 30- Kan slotje op zijn verkocht aan kamikaze Link naar opmerking Deel via andere websites More sharing options...
