Mjoeb Geplaatst September 21, 2007 Rapporteren Share Geplaatst September 21, 2007 Onderstaande recall is nog niet uitgevoerd. Zou het noodzakelijk zijn? Wie heeft hem wel ondergaan? En met welk resultaat. 1993 JEEP WRANGLER Recall ID from NHTSA: 93V083000 Auto Recall Date: 19930511 Vehicle Component: ELECTRICAL SYSTEM:IGNITION:SWITCH Estimated Vehicles Affected: 100000 1993 JEEP WRANGLER Defect Summary: SALT CORROSION PRODUCTS BETWEEN THE STARTER SOLENOID WIRE AND THE ADJACENT BATTERY FEED IN THE BULKHEAD CONNECTOR MAY SHORT THESE CONNECTIONS, CAUSING THE CIRCUIT TO BYPASS THE IGNITION KEY CONTROL OF THE STARTER MOTOR SOLENOID. THE CAR CAN START WITHOUT THE STARTER SEQUENCE BEING INITIATED BY THE IGNITION KEY IN THE IGNITION LOCK. Defect Consequence: THE UNINTENDED START OF A VEHICLE WITH A MANUALTRANSMISSION LEFT IN A DRIVE GEAR CAN RESULT IN A RUNAWAY VEHICLE. Remedy: THE STARTER SOLENOID WIRING WILL BE SEPARATED FROM THE BATTERY FEED WIRE BY RELOCATING IT WITHIN THE BULKHEAD CONNECTOR ON AFFECTED VEHICLES. Notes: CHRYSLER CORPORATION, Citeren Link naar opmerking Deel via andere websites More sharing options...
